Winterizing a fuel injected/ throttle body motor
Bt Doctur
Getting close to the close of another season so do it right or pay the price.
You CANNOT spray fogging compound into a fuel injected motor`s intake. you will ruin the sensors. You need to make up a small gas can with the winterizing cocktail and hook it to the fuel inlet. Gas, Stabilizer, Engine Store, and some 2 stroke oil
You CANNOT pump/pour the A/F into an engine WITHOUT draining everything first. You will crack the block.
Remove the drain plugs and probe the holes to make sure it drains.
