Winterizing for in water - engine raw water drain
Never found a motor where those two small lines were not plugged with sand and gravel
nola mike
This looks like the "Mercruiser hypercomplexification drainage system" on my engine. I drained the water from the component circled in green. According to the part diagram/list #10, highlighted in yellow, is the "HOSE Cylinder Block Drain". To me, this indicates that the block water is drained through these hoses so freezing shouldn't be an issue. But based on earlier comments to this post, I think I need to put the plugs back in and fill the system with antifreeze mix to prevent rust or corrosion - does that sound accurate?
The issue is sediment blocks the drain and need to be physically probed with a wire at the block and manifold exits, like @Scott Danforth said above. You're in my neck of the woods, the water there doesn't get below freezing often, but it happens. We've already had block busting weather. Lots of variables as to how long it will take to crack a block. Those passages are relatively small with no room to expand. On the plus side the block has a lot of thermal mass, so can provide some protection.
Lou C
The only way you could trust such a system, is to accurately measure what comes out when you know the drains aren't plugged, and compare each time how much you drain out. It could work for a few years but there's no way to know when it could clog, and leave one or both sides with enough water to crack the block.
I thought of making a home made version of such a system myself, so I wouldn't have to remove the rear seats to winterize it every year, but I realized I'd never fully trust it. The manifold drains I can get at on mine with no dis-assembly but those block drains are just so low, no way around it, have to pull the seats. I thought of running hoses to the block drains and tying them together right under the crank pulley, but as I said, I'd always wonder if it fully drained.
Like I've often said, for me to keep running an inboard as I get older, if I do get to the point of repowering, the new engine will for sure have a half closed cooling system (block only, that's all you can use with the OMC/Volvo style exhaust) and a remote oil filter. That will eliminate the need for the disassembly for winterizing.
nola mike
I wonder if you could blow compressed air through there. Maybe pinch the other hoses so you know the air is going to the correct drain.
My experience is once those lines are plugged, there was no cleaning them
Lou C
I think the main thing is it's unpredictable. One year they drain fine the next you have to dig it out.
nola mike
Normally it doesn't take much to probe my drains (I get scale not sediment). Reason to plug the other drains is you'd be able to tell whether or not air is flowing freely into the water passage (and direct more pressure to the potentially plugged drain). As an aside, I never got a chance to mess with my drain again, and we're well into block busting season here now...
Scott06
hey you can always drop the 3.7 back in ...
Lou C
No matter how you slice it, on any of the V-engines, 6 or 8, raw water cooling is just a pain. On an in line 4 or 6 the plugs are easier to get at.
The extra money for a half system at least is WELL worth it. I hated how my boat was originally set up with the big heavy bench seat and bulkhead so I changed it.....20+ years ago.....seats lift out easily and the bulkhead opens on hinges that come apart...
I have them listed on the H.A.M.B and Hotrodders for the 4-banger guys
gcarmich
This looks like the "Mercruiser hypercomplexification drainage system" on my engine. I drained the water from the component circled in green. According to the part diagram/list #10, highlighted in yellow, is the "HOSE Cylinder Block Drain". To me, this indicates that the block water is drained through these hoses so freezing shouldn't be an issue. But based on earlier comments to this post, I think I need to put the plugs back in a fill the system with antifreeze mix to prevent rust or corrosion - does that sound accurate?
Ayuh,..... That's the Theory,.....
It falls apart if, or more likely, when, crud in the block blocks the drains,.....
At that point, no amount of antifreeze changes the risk of a frozen busted block, as the antifreeze won't displace the water left in the block, by the crud clogged drains, going to that fancy useless drain system,.....
That convenience can, or will be eventually fatal,....
Lou C
The only way to be sure is to disconnect those easy drain hoses at the block itself and probe those block drains. You’ll get a fair amount of water out of each side. You know I thought of making my own easy drain set up just for those hard to reach block drains but then realized I could not trust it unless I measured what came out each time! It’s foolish to lose an engine because of this. Just do it!
