Re: Winterizing Merc.
OK, Put fuel stabilizer in the fuel tank and run her on the flusher until the stabilizer reaches the carbs. Now spray fogging oil into carb throats, and try to stall her. After you have a good smoke going, shut her off if she didn't stall. let motor drain well. Change gear oil. grease steering and motor fittings. Spray powerhead with anit-corrosion, charge battery and disconnect it. Top off PTT fulid. Have a beer...
