I have two 2001 5.0 EFI Mercruisers/Bravo II units in my houseboat that I leave in the water all of the time. It has raw water cooling that comes through the outdrive to the engine mounted seawater pump.
I recently had the boat hauled to the factory for storm damage repairs and while there had some strainers and ball valves installed in the line from the outdrive to the seawater pump. The strainers are the clear plastic top type. I can see water flow and easily remove the top with one wing nut to clean out the filter. I have the same strainer on my Westerbeke and all I have to do to winterize it is to shut off the valve and pour antifreeze in the strainer until it comes out the side of the boat.
I was hoping winterization through the engine strainers would be as easy as the gen. Last fall I ran both engines until they got up to temp. I then shut off the valves., restarted and poured a 75% antifreeze mix in until it came out the outdrive. I think it took six gallons to do each. Since it was the first time I did this I checked the six blue wing nut drains. The manifolds were nice and green as were the cooler and circulating pump. However, when I opened the block drains out came clear water. I don't understand this. I did this immediately after running them to temperature so the thermostat should have still been open. Just to be sure I drained everything and filled the block up with antifreeze mix in the thermostat well as I always have done. I was hoping to not have to mess with the blue wing nut drains anymore as they are very difficult to remove and put back for a large dude with big fingers.
Any ideas on why the antifreeze mix didn't get into the bottom of the block? Would two more gallons of antifreeze mix do any different?
Rick
Rick
