Winterizing New Suzuki DF25A
timfor1
I have a brand new Suzuki DF25A bought and rigged end of season and have only been able to put ~1 hour run time on her. To winterize (New England) is it necessary to change the gear and engine oils, or just run stabilized fuel for ~15 minutes?
matt167
I have the same motor, which I finished rigging in September and have had it out once. Page 69-70 of the owners manual covers everything
timfor1
Thanks for the answer, but not actually the question I was asking. The manual suggests changing gear and engine oil, which is normal, but with less than an hour use, the oils are practically new and I've read may not need to be changed this first time round. Just looking for confirmation.
matt167
~$4,000 brand new motor, vs ~$40 in fluids. I mean, say you got a defect in the lower unit and it leaked water in, and it freezes and breaks. Warranty is voided because you didn't follow directions. But if you catch it this fall, you drop it off to the dealer before they shut down for the season and have it ready for spring. Personally, while I'm waiting a while for a window to go back out once more, I'm following directions. I think I have 4 hours on my motor. It won't hurt to change oil after 1 hour to flush out machining contaminants
timfor1
Makes sense, the issue I'm struggling with is simply the waste.... A number of sites suggest running the motor every few weeks/months. That's just as likely to put water back in a leaky system - the engine oil currently looks fine and I'll check the gear oil for any milkiness - and again, I may just change them both - it's quick and easy, but it may be pure waste!
jasper60103
I bought a brand new Suzuki DF30A in 2018. We have winter in Minnesota. Follow the motor storage procedure in the owners manual.
Drain and fill the lower unit oil as recommended. No worries about running it every few weeks. That’s nonsense.
timfor1
Thanks, the question I originally asked was new engine and gear oil, then boat used for only ~1 hour at low speed. Draining seems excessive.
mike_i
We don't have a real winter here in So. Cal like you guys do. I was told by a mechanic that it's good to run the motor once in awhile to keep the water pump impeller wet and flexible.
jasper60103
Yeah I understand what you mean. I wouldn’t chance it though unless I could store it in a warm place.
jasper60103
Another thought.
Any reason why you can’t complete the break in process? That way it would be more beneficial to change the fluids.
99yam40
I agree, it is important to break in the motor following their procedures.
need to seat the rings properly and then change the fluids
99yam40
most people run the motor to break it in properly the 1st few days they have the motor
timfor1
While I appreciate the obvious and would love to be out there boating, sometimes life gets in the way. Hence the question, only one hour run time.
KJM
For what its worth, I wouldn't change anything after one hour use, waste of time and money. I might let a little gear oil out to make sure no water got in, but thats it.
99yam40
if laying it away in storage for long period of time it would be a good thing to know for sure no water was in the gear lube, and making sure the shiny metal inside the motor is well protected along with stabilized non ethanol fuel in the motor and tank
