I have a brand new Suzuki DF25A bought and rigged end of season and have only been able to put ~1 hour run time on her. To winterize (New England) is it necessary to change the gear and engine oils, or just run stabilized fuel for ~15 minutes?
Thanks for the answer, but not actually the question I was asking. The manual suggests changing gear and engine oil, which is normal, but with less than an hour use, the oils are practically new and I've read may not need to be changed this first time round. Just looking for confirmation.I have the same motor, which I finished rigging in September and have had it out once. Page 69-70 of the owners manual covers everything
Makes sense, the issue I'm struggling with is simply the waste.... A number of sites suggest running the motor every few weeks/months. That's just as likely to put water back in a leaky system - the engine oil currently looks fine and I'll check the gear oil for any milkiness - and again, I may just change them both - it's quick and easy, but it may be pure waste!~$4,000 brand new motor, vs ~$40 in fluids. I mean, say you got a defect in the lower unit and it leaked water in, and it freezes and breaks. Warranty is voided because you didn't follow directions. But if you catch it this fall, you drop it off to the dealer before they shut down for the season and have it ready for spring. Personally, while I'm waiting a while for a window to go back out once more, I'm following directions. I think I have 4 hours on my motor. It won't hurt to change oil after 1 hour to flush out machining contaminants
I bought a brand new Suzuki DF30A in 2018. We have winter in Minnesota. Follow the motor storage procedure in the owners manual.Makes sense, the issue I'm struggling with is simply the waste.... A number of sites suggest running the motor every few weeks/months. That's just as likely to put water back in a leaky system - the engine oil currently looks fine and I'll check the gear oil for any milkiness - and again, I may just change them both - it's quick and easy, but it may be pure waste!
Thanks, the question I originally asked was new engine and gear oil, then boat used for only ~1 hour at low speed. Draining seems excessive.I bought a brand new Suzuki DF30A in 2018. We have winter in Minnesota. Follow the motor storage procedure in the owners manual.
Drain and fill the lower unit oil as recommended. No worries about running it every few weeks. That’s nonsense.
Yeah I understand what you mean. I wouldn’t chance it though unless I could store it in a warm place.Thanks, the question I originally asked was new engine and gear oil, then boat used for only ~1 hour at low speed. Draining seems excessive.
Another thought.Yeah I understand what you mean. I wouldn’t chance it though unless I could store it in a warm place.
Time, unfortunatelyAnother thought.
Any reason why you can’t complete the break in process? That way it would be more beneficial to change the fluids.
