chucky112233
- Joined
- Jun 23, 2007
- 31
Hello all.. Want to thank eveyone in advance.. I just recently got a 1980 Sea Ray 245 and have done all that i know to winterize..When i went to winterize it i ran coolant through and had it spitting out the back but none came from the prop..I ran it for prob 3-5 min. Should i be concerned?(mercruiser outdrive).. All plugs and drains all have coolant in them..Second question it has a kenyon propane stove with the main feed line running under one of the seats in the cabin.. It has a flare fitting that is it.. What tank size should i need?I take it i need a regulator too.. Also it does not seem real safe if it has a leak.. Maybe run one of the small camping tanks and disconnect when not in use?I dont see a spot for a propane locker and that is a long difficult line to run from the swim platform up.. Also the boat have just a portable potti in it,i think you have to carry the whole thing out to dump it,,i had a friend give me a toilet that has a storage tank and is ment to be pumped out.. I have never owned either.. Whitch is better? I would have to install the pumpout one with i would imagine would not be 5 min... Thanks to all!!
