- Joined
- Jul 23, 2011
- 53,252
your right, the manual states how to completely drain the block, heads, manifolds and plumbing.
it also states that the following are optional for long term storage
disconnecting your fuel system, running it on a remote tank with 10% Quicksilver 2-stroke blah blah blah
and in a side note under that
if added corrosion protection is desired, remove thermostat housing and fill block and heads with Quicksilver PG AF.
Winter is not long term storage. Then again, if I sold quicksilver products, I would probably put their use in the manuals.
The key to the manual. Drain the water first (most will attempt to suck AF up muffs without draining), buy quicksilver products
