badly bent or broke
Thread starter- Joined
- Jan 5, 2008
- 34
I've owned my boat with a '97 75 hp Force for over two years now. The past 2 years I have kept it wintered in my garage (above freezing). I used it at least once monthly during the winter so I didn't actually "winterize" it other than changing the gear lube and using a fuel stabilizer. This year it will be necessary for it to be kept outside over the winter. I will change the lower unit oil but am wondering if there is any water left inside the engine that would freeze and cause a problem? To conserve space, I trim the motor down when parked at home. Does this allow all the water to drain? I hope to use the boat occasionally over the winter so I don't want to do something that will unwinterize it or am I better off to but it in moth balls until spring?
