eddie haskell
Thread starter- Joined
- Apr 5, 2015
- 87
Winterizing, best to run gas out of the motor on a 2 stroke or drain the bowls instead?
I would not run a large 2 - cycle motor with multiple carbs dry. If you do, some cylinders will be running without oil, as some carbs will run dry first. Instead, put stabilizer in the fuel and run her for a few minutes to distribute. Spray some fogging oil into carb throats and try to stall her. When she is smoking well, stall her or turn her off. Let motor drain, and then change the gear oil. Spray with corrosion guard, grease the zerc fittings, remove the prop, disconnect and charge the battery. Also, grease the steering.
