I have a twin 4.3. alpha 1 gen 2 Sea Ray ....4 barrell carbs...(1998)
I have a few questions regarding safe winterizing....
I have the outdrives off..... can I run the engines for 30 seconds to fog them???
Once fogged, I intend on removing the blue plugs (4) on each motor.... be sure they are free of debris and drain the blocks....
Then I will remove the thermostat housings.... Question here... should I run a bit of compressed air through the intake where the thermostat mounts
to be sure the block is clear of debris or water?
Then my plan is to reinstall the blue plugs and fill the blocks with antifreeze...
Does this seem safe and appropriate???
TIA
TIA
