ledzeppelin135
Thread starter- Joined
- Jul 27, 2011
- 129
Hi, I recently rebuild the carbs on my 1983 Merc 50hp and disassembled everything and all the wire connections, I took pictures and followed the diagram to wire it all back but I have a single black wire coming out of the main engine harness that seems to run the the black 1.5" long cylinder that is mounted on the right side of the front plate of the motor. The wire length seems to reach that but I am assuming an all black wire is a ground so that would not work on that cylinder. Can anyone please tell me where this wire belongs as I will be going to the lake on Tuesday. Also, I talked to a marine place that told me the reason my motor is bogging out at wot is probably the ignition module? If I am going at WOT it will last for about 5 minutes when warmed up and then it bogs down and I can run it more than 1/4 throttle or it dies. Can someone please tell me how to diagnose this "ignition module" and tell me what this guy is talking about. Thanks alot for your help!
