Wire connectors question per your with Yam outboards
Yamadogg
I have a Yamaha 50 2 stroke (2004) (50TLRC). This picture is in my 2004 Yamaha 50 2stroke: Has anybody dealt with this type of wire connector ? I don't know whether it's a permanent connection ( crimp on ) or a detachable connection ( like bullet connectors ). I need to splice a wire into one of these wires and want to start pulling a connection apart that's meant to be permanent and start fouling up my wiring. Any help ? Thanks.
99yam40
yep, just pull it apart
It is just a bullet connector
Grub54891
And why do you need to splice it? If you are adding something, and need a power source, there must be a better way than cutting up the harness.
jbcurt00
In the 1st pix, there are 2 parts to the 1/2 of the connector you're touching. Almost looks like this might be both a fusible link and a butt connector.
The joint between the green rubber piece your touching and the other rubber part look to be a butt connector. But what is the seperate metal ferrule inside that rubber boot at your finger? Why is it there and seperate?
Yamadogg
Thanks for replies -
GRUB54891 : i need to attach my STARTER ISOLATION ( in Bluesea ACR ) to the IGNITION SWITCH SIGNAL which would be the small brown wire on the small post of the starter solenoid ; but it looks like a real pain to get under the starter solenoid [ lots of other wires to push and pull out of the way. So I am investigating if this connector on this wire is an easy place to make my connection.
jbcurt00 : . I don't know what's in there; can't really see a lot. I never thought of a fusable link but.... I was looking for a Yamaha outboards direct forum but didn't find one. Maybe i'll try calling them, Or ask at my Yamaha marina. There are several of this type of connector in my motor.
Thanks for the replies... Don
Yamadogg
99yam40, Do you have experience with these? Is there a fusable link in there too ? See other comments re. my reason for asking. Thanks
99yam40
I just saw it looked like the bullet connectors on my C40.
I do not know if it has anything else inside the plastic or not.
Your local dealer should be able to help to with info
Yamadogg
Here's what the BlueSeas rep. told me to do ( verbatim) : [FONT=Times New Roman, serif]Once you figure out [/FONT][FONT=Times New Roman, serif]which wire is active during engine cranking [/FONT][FONT=Times New Roman, serif]only then simply clip that wire and splice it into a new wire for the ACR.[/FONT]
m But the solenoid post might still be the easiest; I just hope I don't pull anything else loose trying to get to it.
