Re: wire size
If you search this forum you will find a lot of posts on this.
There are 2 considerations when picking wire size. The first is that it has to be large enough so it does not heat up and cause a fire.
The second is that there is always a voltage drop when you pass current through a wire. You want to make sure the voltage delivered to the equipment is still high enough.
So when you pick the wire size you first need to make sure it is big enough to not burn up, then keep the voltage drop below a certain percentage.
I can give you a basic rule of thumb for house wiring on size. 12 gauge will carry 20 amps, 14 gauge will carry 15 amps. From there you double the amperage every time you go down 4 gauges and halve it everytime you go up 4 gauges.
For example, 8 gauge is 4 less than 12 so it would carry 40 amps.
For voltage drop there are a number of calculators on the web. Here is one
http://www.southwire.com/voltagedropcalculator.jsp
Keep in mind that when you measure the length of the circuit you need to account for both directions. The length of the wire from the battery and the return.
Hope this helps
