gpfishingdude
Thread starter- Joined
- May 1, 2012
- 538
I was wondering if there is a list of wire sizes needed for everything that we normally have wired in on the pontoon boat. I know there will be some slight differences caused by the length of run but there should be some common sizes required too because of the amps required for the item wired in. For example I know that navigation and anchor lights draw very little amps so 14 or even 16 ga. wires would do for them. Where I would want a little heavier gage for a live well pump and heavier yet for an anchor winch. I know that I have to use common sense for the main wires between batteries and other places that might have a higher draw and maybe for wires that run the length of the boat. I am not against using wire that might be a size too big, I just don't want to use a size too small. Thanks
