wireing diagrams
jim765
in need of a wireing diagram for a procraft 1510 boat,1988 have eng diagrams for motor,but not for boat,any help would be apriceated,
oops!
Re: wireing diagrams
hi jim.....welcome to iboats !
lets get this moved to where out electrical wizzards can help you
NYBo
Welcome to iboats!:cool:
Wiring diagrams are pretty generic, and there are several to be found in the stickies at the top of this forum section. Are you having a specific problem?
jim765
cant get gas gauge to work,also person that had boat befor used lamp extension cords for wireing ,had to laugh when i found that lol, have tried all suggestions from here but no luck.oms test,voltage ok ,grounding,tried new gauge on it,just no luck,thinking about replacing all wireing,also found no fuses,fuse block,other than that boat looks like new,always stored,plus,60 hp evenrude with tilt and trim,every thing works great but gas gauge,also test the float sending unit,it worked ok
NYBo
Adding a fuse block is a good idea to keep things safe and organized.
Here is a fuel gauge wiring diagram, courtesy of Silvertip:
