wiring 16' bass tracker.... my plans correct?
ajp1977
Hello. I've been researching some diagrams here at the site....I have a cranking battery for the motor itself. My house battery I'll be running the positive lead in 8 awg wire to my switchboard/fuse panel. 6 inches from that house battery on that run will contain a 40 amp circuit breaker...the switchboard should contain the terminal bar at the switchboard. I will install a neg. bus bar to which the neg. feed from the battery will attach to, also ran in 8 awg. Soundcorrect so far?
ajp1977
Re: wiring 16' bass tracker.... my plans correct?
Sorry for punctuation..I'm doin this via cell phone.... the trolling motor will also be ran from the house battery on a circuit by itself..also having a 40 amp circuit breaker on positive side within 6 in of battery....acc. will be wired in appropriately with there switches and to the neg ground bus bar...running those in 16 ga
