FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1990 25 johnson that the kill switch button on the tiller handlebroke this morning and my motor wont start, any way i can wire around it so i can run my boat? a quick and easy fix
The kill switch is usually open to run, closed to stop. If you disconnect the wiring and insulate it you should be able to run Ok .... but you wont be able to stop it so easily .. you'll have to disconnect the fuel and wait until it dies or wire in a temporary switch.
Any old toggle switch will work to kill it. You can even use on old light switch. They're less than $.50 at Lowes. Not pretty, but ok 'till the new one gets in.
you should be able to cut the black wire that geoes around to the plug you can run it out of gas or choke it to turn it off. all the kiil switch does is send a ground so a toggle switch would work fine too
