Wiring Diagram - Cut off switch
Incorrigible
Engine: J225TXESS (1990 225hp)
On the wiring diagram one of the black/yellow (engine cut off/grounding/shut down) wires runs to what is labeled as the "Cut off switch"
Which switch is this?
Thanks
daselbee
Re: Wiring Diagram - Cut off switch
Ignition switch in the "off" position. The "M" terminal.
Barnacle_Bill
That wire also goes to the emergency cut off switch and probably to a mercury switch on the motor to keep you from starting it when the motor is tilted up.
Craig-
The raised M terminal should have no continuity with the other M terminal (ground) when switched on and have continuity when in off position and therefor ground the raised M (old convention Magneto) terminal that your kill wire (blk/yel) connects to.
