Re: Wiring diagram for 1971 3 cyl 60 hp Evinrude ignition / gearshift harness
RB<br /><br />Thanks.<br /><br />Without going into detail on each wire, the problem is that I have to wire the harness up to the control box and ingnition key but the spade connections for the electric shift and the screw lugs for connecting to the ignition, along with a few other spade and screw lug connections on the control box, don't fit any obvious pattern so I have no idea what goes where, apart from battery, ground, and start wires. <br /><br />I can probably work most of it out with continuity and voltage testers and a bit of luck, but I'm worried I'll fry the expensive bits if I don't know what goes where before I start experimenting.
