wiring diagram for tilt & trim 85 Evinrude
clevecan
If anyone can help me with wiring diagram to hook up my tilt & trim?
I just replaced my outboard merc, to a evinrude. the merc,had the thing on the side of the motor. The evinrude has a box that goes in the boat the wires
hook to. any help please.the boat is a 88 model and the evinrude is early 80"s
Sherman
Re: wiring diagram for tilt & trim 85 Evinrude
It looks like the plug on the box has three wires, Blue/white it down, Green/white is up and the red/white is the positive lead.
ezeke
Click the thumbnail
clevecan
Ok thanks Guys I'll use this and get it hooked up.....
ezeke
It takes more power to raise the motor which is why the 1979/1980 PT&T only has one solenoid to raise the motor; blue and white is up/trim out and not down/trim in which is green and white.
clevecan
Ok my 79 evinrude power tilt&trim Only has two wires comming out of it!
A Green wire and a Blue wire...
I'm lost.........
clevecan
It apears my trim motor has two wires like the 82 thru 90 evinrudes even though the model# says 85999R which can be a 79-80 model from what i,ve seen.
so might need a wiring diagram for that model?
ezeke
OK, do you have either a relay box or solenoid box for your PT&T?
If so could you describe what is inside as relays or solenoids?
clevecan
OMG ,,,,LOL wow, OK let me see if I can fix this prob? thanks ezeke alot
ezeke
Check my edit on the previous entry.
tinner45
I seen your diagram PT&T and thats the way I hooked it up but it powers one way but not the other way. i better start at the begining. The PT&T worked when I got it the man had wires everwhere. After fixing the leaks I removed some wires that the diagram didn't have. the motor wasdn't good so I had it rebuilt. I checked the motor to see if it was working and it is. But when I connect the wires to the junction box (where the silenoid is) the motor work one way. the wires are connected just like the diagram. I had to put a three way switch. 1 is up 2 is off 3 is down.
Oh I forgot the engine starter quit working.
I found on another site forum a two solenoid hook up. Can I switch my single solenoid to a two solenoid system?
