Re: Wiring Diagrams
Also made some other measurements. Voltage with ignition on and engine not running=12.65 no AC. Makes sense as this is battery voltage. Voltage on purple with engine running 13.86 with no AC. This seems a little low to me as I thought charging float voltage should more like 14.3V. I did also try pulling all of the fuses in the helm mounted panel and the ignition fuse still blew out. since the remaining equipment is not run from the ignition fuse (radio, trim, blower, horn, bilge pump, anchor/nav lights cigarette lighter as I can remeber off of the top of my head) and all of those operate fine after the ignition fuse blows, I am sure the problem is in the engine (power plant). Basically, since most all of the other equipment operates after a blown ignition fuse it can not be my problem. When the ignition fuse blows the oil press, batt volt, fuel, tach etc all go dead and the engine quits. Since it is not possible to disconnect or isolate the charging, Ignition and Fuel circuits and run the engine, i am unable to further isolate the problem.
