bang4dabuck
Thread starter- Joined
- May 24, 2009
- 296
I am working on an old Whaler. I switched out the Evinrude Control box with a Morse MT3. In doing so my ignition is mounted to the console. I am hooking up gauges in this order water pressure, voltmeter, temperature (1), temperature (2) and tachometer. These are on an '87 Ev 90HP. I daisy chained them as I had read but when tested the voltmeter loses volts when all are connected just as the tach, as the last on the chain is reading below 9 volts. Is this wired OK ? I tried 2 tachs and they don't want to work. I can understand one being bad ...
Also when it says to IGNITION which post on the ignition are they talking about "A" or "B" ?
