Cargeena 2
- Joined
- May 10, 2010
- 18
I just bought a 3 gang switch panel at my local Bass pro Shop and I have some questions about how to wire it to my 12 volt battery.
It has the 3 switches with separate fuses for each plus a cigarette lighter and a dual toggle switch for the battery meter (test 1 & test 2).
I see how to wire the main positive & negative terminals to the battery but I am having trouble with other wires attached to this panel.
Two red wires come out of a small wired box on the back of this panel for the battery meter, where do I wire these two?
Also, there is a fuse under the cigarette lighter that has another red wire coming out the back of the panel, where would I wire this to?
I believe that on the back of each switch, I would wire the positive & negative for each device I want to run ( stern light, bow light and an extra), is this also correct?
Any diagrams or links would sure be appreciated.
