Wiring Lights
pscrabber59
Need some help on a small trailer lights connections. What can i use to seal(watertight) the wiring from the trailer end to the light-wiring? A friend said "heat shrink tube" don't know what that is. The last time i did any re-wiring on a trailer it was years ago.
Any advice is appreciated
sw33ttooth
Re: Wiring Lights
heat shrink tubes are like barrel connecters except you use a lighter or torch to shrink the ends so water wont intrude. i wouldn't worry about them that much my lights work great i never unplug them and i used normal barrel connecters. i think the last time i was in car quest they had a package of 20 heat shrink tubes for 4-5 bucks, i am sure antozone or napa would have them as well.
a1nowell
Re: Wiring Lights
I recently rewired my trailer and I seal all the connections with liquid rubber. You can find it at most auto parts in the wiring section.
pscrabber59
Re: Wiring Lights
Thanks for the repiles guys, my friend said he has some heat-shrink tubes i can have so I'll have something to do this weekend
windy5849
Re: Wiring Lights
+1 on the liquid electrical tape.It comes in a bottle with an attached brush and makes a water proof connection.It comes in different colors for around $5.00.
BatDaddy1887
Re: Wiring Lights
...just in case you need a wiring guide....here you go....hope this helps.
