Wiring Problem? Need help please;-( 1987 Mercury Engine 175hp )-:
NESAR
I just got this merc. This motor will be used for a Search & Rescue boat We are all Volunteer.
Here it goes. There ate 2 wires that come off the trim pump one is brown wire stripe. I think the other wire is black and it's ground, it's connected. now there are 4 or 5 wires that comes from the control shifter and then the main wiring harness that plugs in. I don't know where the colored go is there a picture or a wiring diagram I can get for this?
The trim wont go up and I am only getting spark on one half of the 6 cylinders. Any help would help us.
I have jumped the tilt from the solenoid motor works but don't put up the tilt and no clicking from the solenoid. :mad:
Does it half to do with that wire not being hooked up on the tilt?
Does the spark have to do with the wires not being hooked up? ( Main harness is hooked up)
NESAR
Re: Wiring Problem? Need help please;-( 1987 Mercury Engine 175hp )-:
any websites i can use for info?
dlplost
Brown/White stripe is trim sender to trim gauge, not needed for operation.
There are 2 types of trim pumps, 2-wire (usually a replacement pump) and 3-wire (in 1987 this was standard)
2-wire pump has 2 wires from the pump going to several relays. To test pump, connect + to one wire, - to the other, pump shoudl run either up or down. Reverse the + and - and the pump should run the other way.
3- wire pump has Black (always ground), Blue (+ here trims UP) and Green (+here trims Down)
For rest of wires, see here..http://www.maxrules.com/fixmercwiringcodes.html
NESAR
Thanks for that website great tool to have.
