belleview3
- Joined
- Sep 14, 2009
- 78
I?m installing a stand-alone 120v. HVAC into my ?99 Wellcraft Martinique 2600. It?s a 16k btu unit that?s going to turn my boat into a deep freeze (yep, it?s way oversized, but the price was right). Piping it in and installing the unit behind the aft berth bulkhead should be no problem. My boat has a single 30amp shore power connection that I?d like to use for the source to the unit. The existing load is the baby fridge (5amp), microwave (5amp), battery charger (5amp) and an outlet. The existing source should handle the load, especially if I monitor what is being used. The existing distribution panel on the port side of the boat doesn?t have any additional space for another breaker. Getting the wiring from the starboard side to the port side is going to be a b!@ch. Can?t find any info on how it should be routed (it was an option that wasn?t documented well). May have to get creative.
My question: Should I intercept the line wires above the breaker panel and add a terminal block to add another circuit and breaker or just piggy back another set of lugs on the load side of the main breaker to add the circuit? All of the breakers have screw terminals with crimped ring connectors. I prefer adding the circuit to the load side of the main to keep it as the full-load breaker and switch.
