braindead0
- Joined
- Aug 26, 2003
- 169
I'm planning on replacing all the wiring in my boat, it was done by an eeediot ;-). My plan is to get a new battery box, install a new fuse box (water resistant marine) and put in a circuit breaker (rated at amps the fuse box is rated at) at the battery and suitable sized wiring to the fuse box.<br /><br />I'm thinking about running the power wires, bilge and rear light wires and motor wires through a peice of PVC to act as a conduit. <br /><br />Once I've got the fuse box near the helm, I'll run appropriate wires (and fuses) to all accessories. <br /><br />The plan is to solder all joints, and seal with liquid electrical tape... and of course strap all wires to the boat outta the way (currently there are some hanging in the bow seating area).<br /><br />I'll be using 'marine grade' wires all the way of course.<br /><br />Anything else I should be doing? I think there are two 'camps' re: soldering vs. crimping connections but I think all the arguments against solder (corrosion and the like) are perhaps mitigated by using liquid masking tape. Perhaps some RTV/silocone as well.
