Andy in NY
Thread starter- Joined
- Oct 25, 2007
- 2,109
Okay, i am ready to tackle some wiring issues (nothing major). so far, i have removed the switches for accesories and the fuse block, and am going to replace with a new 6 gang fuse/switch panel. the wiring that comes up to the helm to power stuff is seperate from the main harness, but has a few splices in it, and want to run new 12v power and ground from the battery.
what gauge should i run from the battery to the panel? should the ground be the same size as the power?
that TYPE of wire should i use? can i use rehular automotive type from an auto parts store?
should i put the anchor lights and nav lights on seperate switches?
can i combine the radio and depth finder on the same switch?
can i run speaker wire in the same loom as power and not get interferience? can i run the wire for the transducer in the same loom as power?
i think thats it for now... to get me started.
