Wiring up a Cigarette lighter on boat
crzywvguy
I already have a cigarette lighter on my boat but it doesnt work, how can i fix this?
rickdb1boat
Re: Wiring up a Cigarette lighter on boat
Make sure, using a voltmeter ,that you have 12 Volts going to the lighter. If so, replace the lighter. They do go bad rather quickly from rust and corrosion inside the socket...
rc581
if no corrosion inside, then make sure inner sleeve is tight on outer ring. otherwise when u push the lighter in, it will not make contact and not heat.
phatmanmike
make sure its a stainless one made for marine use or it will only work for as day, maybe less
neumanns
Check the buss bar also, and follow the wires. Mine was wired to the accresorie switch.
