Make sure, using a voltmeter ,that you have 12 Volts going to the lighter. If so, replace the lighter. They do go bad rather quickly from rust and corrosion inside the socket...
if no corrosion inside, then make sure inner sleeve is tight on outer ring. otherwise when u push the lighter in, it will not make contact and not heat.
