redneckgearhead
Thread starter- Joined
- Feb 13, 2017
- 18
Found the trim switch held in place with a couple of wads of electrical tape and most of the mounts that hold the plastic cover on busted off. After looking at the replacements and seeing that the new ones may not last long as the mounting points still look weak. I decided to repair the original one. I filled the cavity where the switch goes with aluminum foil and filled the rest with plasti weld epoxy and the mounting locations as well. Now the switch is held in with two screws instead of just one and the rest are solid points as well. I wont be able to get it back on the water for a couple of weeks.
