- Joined
- Mar 8, 2009
- 43,914
If I find that diode how do I test it? Scott said there is a diode test on a multimeter. Mine doe not have that. Can’t I do a resistance test on it? Is this a common problem? Would this cause me to lose power at the helm back in June? And what about the melted relay socket
Yes you can check it with just resistance. If you get zero ohms then its open and from your problem that is what the issue is
Yes, if the diode opens its like cutting the wire.
