Won,t Start
edgar
70hp chysler cranks over ok but only backfires?Motor is on a stand in garage
zoltang
Re: Won,t Start
did u check if theres gas going in? Motor should be conneted to a water source.
edgar
Re: Won,t Start
I use the muffs when I crank it.Ialso tried spraying gas directly into each carb.
zoltang
Re: Won,t Start
well, spraying gas into the carb only keeps the engine going for a short period of time, have u tryed cleaning out the carbs?
the flowter might not be working properly
eurolarva
Re: Won,t Start
A back fire is usually a timing issue not a fuel issue. Are you sure the plug wires did not get reversed?
