81 Checkmate
Thread starter- Joined
- Jul 20, 2010
- 1,360
Vacation last week...... Having issues with the Pontoon.
2001 - 3.0 Merc I/O
Serial Number - #OL647903
1. It will start no problem...crank and it fires.....but it wont idle. You can rev it to 3 grand and hold it there and it has a very slight miss...but when you back it down to idle it quits.
2. Its getting fuel...change the fuel filter at carb. Had good pressure on the fuel line.. No fuel/water seperator installed!
3. New spark plugs and cap - rotor/button...Its getting good blue spark...becouse it runs
4. 1 can of sea-foam and 1 bottle fuel additive....about 15 gallons total, 5 gallons of 6 month old gas and 10 gallon of 89 fresh.
I did not check to see if there is water in the fuel... My bad will do this weekend. Its prob what the issue is!
But.... when it's running the volt gauge is reading almost 18 volts...not sure if this might be the issue?
Any thoughts?
2001 - 3.0 Merc I/O
Any thoughts?
