joseph fogarty
- Joined
- Aug 2, 2009
- 10
i havea 1989 200mariner that will run and idle fine on the hose but once you put it in the water it wont ide or go it will keep shuting off you can start it and rev it up but it wont go once in gear if you keep trying and go wide open it will take off and run fine at high speeds but once you come back to idle it will shut off had carbs rebuilt its got a inline filter and a water seperator on it i cant figure it out mechanic said compression was good can you help ther arent no adjustments on the carbs
