Vic.S
- Joined
- May 4, 2004
- 4,719
Re: Won't start.....help!!!
If the insulation on the coils is cracked up they need replacing.
Points..well you can clean them up and reset then ( 0.020") at the same time as you inspect the coils. Just as you would for coil and points ignition in a car. Must be scrupulously clean ... not even a fingerprint!
Condensers difficult to diagnose other than by replacing. Only ever come across two failed ones in 50 years. One in mates car ( MG 1100)... that fooled me.
The other in an old Viliers engine recognised the symptoms 2nd time around!
Coils, points, condensersf there isn't enough spark what's the most likely issues?
