Re: Won't start
Voltage to the ignition module must be measured with a DVA Meter or DVA Adaptor on a standard VOM, using just a VOM WITHOUT the DVA Adaptor may give you false readings, i.e., voltage but NO amperage, and the ignition still will NOT function.
Just because the battery is new does NOT guarentee that cranking speed is adaquate, poor connection on the other ends of the cables, or the starter cable, or within the solenoid, or dirty brushes in the starter can still be a cause of slow cranking speed and LOW DVA Voltages to the ignition module.
What are the voltages you measure and how did you measure them?
Generally, a motor will NOT lose fire on ALL cyl's all at once, except for slow cranking speed. That does not mean that it is impossible for the module to be bad.
