Wood Finishes?
littletoes
Well the 'ol finish on the wooden parts on my fiberglass boat are peeling, and need redone.
What type of finish is best for full water and sun exposure? Of course it will be covered when not in use, but I don't want to have to do it again real soon!
Thanks for any help!
wire2
Re: Wood Finishes?
I've use Ports marine finish on my teak bits for many years, a light sanding, then 2 coats usually lasted 5-6 seasons. Unfortunately, I don't think it's available anymore. Look for something specifically made for wood in weather extremes. When my tin of Ports is empty, I might try Behr waterproofing stain. It stands up very well on my outdoor deck.
Tahorover
Re: Wood Finishes?
Good old Varnish. The best is made by Epifanes
The varnish on my hull is 8 yearsn1306202166_30179881_5796527.jpg old in this photo
BWT
Re: Wood Finishes?
My preference is a combo of West system epoxy (their 207 hardener which cures water clear and has UV filters built in) and a good quality marine varnish (Petit or Epifanes). 2 full coats of the epoxy and 2 full (un-thinned) coats of varnish will last quite a while (2-3 years before touch-ups / maintenance coats are needed).
25thmustang
Re: Wood Finishes?
I haven't even had the boat in the water with the wood redone, but I went with the Cetol Natural, and the Cetol Gloss. I plan to keep and eye on how it holds up, but I really hope it lasts a few seasons with some scuffing and a coat of clear per year.
littletoes
Re: Wood Finishes?
Thanks Guys!
Sounds like some great ideas, and I'll first see if we can get some of that stuff localy.
dan bateman
Re: Wood Finishes?
have stained my wood trimand put minwax helmsman on it two coats. three days in sun varnis leaves in spots. what can i put over this to look nice for at least a summer.
Woodonglass
Re: Wood Finishes?
Sand it down with 120 grit paper and use 2-3 coats Epiphanes or Cabots. I MUST have GOOD UV resistance.
BWT
Re: Wood Finishes?
I just finished a video on a variation of varnishing teak (an epoxy / varnish combo that I mentioned in a previous post). Link is in my signature below. Have always had great results and the appearance is unbeatable. :p
