Wood Trim Help
79Merc80
Hello everyone. My 1981 Glastron SSV194 has a lot of wood trim. Someone varnished it and it's flaking off. Do you know of a way to get all the varnish off without sanding the wood away? Also several pieces have grooves that a sander can't get into. Also, should I just oil / water seal the wood??
Thanks for your assistance.
Craig
joelhusvar
Re: Wood Trim Help
Craig,
I'd use a good paint and finish stripper from the hardware store. It won't damage the wood or take you days of sanding. Then I'd put a good coat of stain on it and finish off with some clear. They will come out great as long as you wait the amount of time it says between coats and closely follow the directions
- Joel
Craig
Woodonglass
Re: Wood Trim Help
That is prolly teak. Klean Strip in the Orange can would be my recommended stripper. Sikkens Makes a good teak oil. Soak it till it pools and won't take any more. Let dry for 24 Hours. Leave it natural and reapply the oil every week, or apply 3-4 Coats of a good UV protectant Marine Varnish. Epiphanes makes a good one.
Bayou Dave
Re: Wood Trim Help
I sanded my Teak all the way down to bare wood using a random orbital and hand sanding. Used 80 grit and then 100 grit to make it smooth. Then I used Watco Teak Oil and put 4 coats on it by saturating the wood, waiting an hour and a half between coats to make sure it soaked in good. I put a coat on once a week for a month and now put a coat on monthly.
Yacht Dr.
Re: Wood Trim Help
Scrape the crap off that teak with a good sharp scraper :) ..
Sand with 80 grit and put 5 coats of teak oil on it.
YD.
