Woods 9180RD Batwing came apart
Pull the my Woods Batwing Turf mower in the fields behind my vacation rental. I keep an eye on maintenance checking gear box oil level, belts, blades, all that kind of stuff. Finished cutting the back side hills and was in the home stretch on the front side which is mostly flat. Hear a loud couple bangs, stopped the tractor and disengaged the PTO.
Then see this, took pic at my house
Note the gear box, it's not bolted down
One by one over time the bolts loosened and fell out through the bottom. There was only one of the holes in the lower gear box that had a slight nick, meaning the box didn't come loose until the last thread of the bolt broke.
It busted the quick connects on each wing and one yoke. I spent today getting new bolts, unbending the braces and other stuff. It didn't hurt the gear box so reinstalled with new grade 8 bolts using red loctite. Will be looking for 2 wing PTO shafts Monday, of parts to fix the ones I have.
The shafts use quick connects on both ends which means they cost more. One is square shaft and other was replaced at one time and used the 3 side round. They are series 4 and 26x41, so should be able to use a 30x40 which is regular size, or will cut to fit
That sucks
Look into prevailing torque locknuts
No nuts, 1/2 bolts go in thru bottom
Finding nyloc bolts would be nice but none in grade 8
Looking for 2 PTO shafts in the 30 inch compressed with Quick Disconnects on each end. Found 3 different vendors and like Sutter Bros in OH the best. Going to look local tomorrow to see what I find. Can always get a longer one and cut it down
Looked a bit further and found one of the belts broke, so no big deal. But ..... also found one of the pivot points has a broke weld, that's going to take a bit more work, bummer.
Have 2 welders but I'm not that good, but the question now is do I try and hope it works out, or take it to a "real" welder and let them fix it?
I say practice a minute or two before hand. You have this
dingbat
You got to love working on farm equipment.
Bush hogged the back pasture Sunday morning. Got back to the barn… the tail wheel assembly only made it half way.
Weld breaks on equipment are typically vibration related. Prep, not welding skill is the key here. Anything short of 100% penetration will crack/break again. Grind to base metal on both parts and start from scratch. Run hot…use the arc “gap” to control puddle temp. Once the root pass is done you can back off the temp a bit to make it look pretty.
Welding and Planting are two things where penetration is critical
Pmt133
I'm not an excellent welder by any means... my knee jerk response is that a grinder and paint can cover all sins. :LOL: That being said, I agree, you got this.
Also, maybe nordlocks for the bolts?
Mc Tool
Smear a bit of filler on the bad spots too before painting 😁
flashback
man what a mess. Glad you weren't injured. that could a been alot worse..
Yes, thankful lady luck was on my side
Got the tab bent back where it should be and need to move the unit over to my shop to even use the welder. Guess I could add a double 50 amp breaker in the barn (have 200 amp service) and bring the welder over.
Have a old Lincoln stick welder and have never been good with it at all. Also have a Hobart 220 Mig welder with no gas. Have flux core wire so it wouldn't look as pretty, but I can get the amps up
My finger is at the end of the crack, so it cracked about half way. It was bent out and I hammered it back in place. The 3/4 inch pin that goes thru it is not bent but it did brake the keeper off the back so I can wled a piece of rebar on that end20260821_150254.jpg20260821_150317.jpg20260821_134322.jpg
Grind out the weld with a 4-1/2" grinder. Then hit it with the flux core
Bought 2 PTO shafts off amazon for the ones that were damaged. They show there quick disconnects on both ends were the ring type. The ones received were the single spring pin
I'm sending them back and have ordered others like I wanted from Farmer Bob;)s
Mc Tool
Scuse my ignorance but whats the difference ....I mean obviously the latching is different , is one better than the other ? 🙂
Original type uses 3 latching points, new uses just one. PTO shaft spins and is it as balanced as the other, unknown. I don't want to try new style connector when old style has worked for many years and there has been no reported issues that I have heard of. Old style is what I ordered, new style is what I received.
If you ordered a Alpha drive and received and new wizbang drive would you be ok with it? So if you want to try new style and after a few years let us know how that has worked out and I might change my mind.
Mc Tool
Yeah , I get that when you order something and when it arrives it doesnt look like what you had in your minds eye its heading towards negative , but I guess if you have the time and can be bothered sending it back and ordering another thats what to do ....but the new type might be better 😁 and if your in a hurry to get a job done . Im no expert but I have seen and worked ( in a neighbour just helping out sort of way )on many of the pin type on various pto driven things , like mowers ,grain augers and sprayer pumps .
😁 I bet you dont let them bolts come loose again 😁. I hate it when stuff like that happens .🙄😁
dingbat
The “new style” coupler has been around for as long as I can remember. The quick disconnect setup didn’t come out until much later
Welded up a piece on pin and installed. Did get some penatration and doesn't look the great but good enough .
I started developing essential tremors a couple years ago so makes it difficult to keep my hands steady
As before im not a welder but usin .045 flux wire and running setting 4. Ground a grove down the Crack then more passes . Ground some looking for holes and found just a few. More wire and it at pretty but think it will hold
