weider1717
Thread starter- Joined
- Sep 2, 2008
- 315
I was looking into getting all my bellows replaced on my 85 MR outdrive serial number 6886314 and was getting quotes from 560 to 1200 worse case they said.
well came home today and kicked the trim up ALL the way so I could see the bellows good.
like I remember I saw a tear towards the front of one of the 3 bellows..well unless I'm missing something here thi bellow with a tear in it I can replace without taking the foot off.
It's the bottom bellow, below the shift cable bellow which is slightly above it and to the right, then there is a very LARGE bellow.
the shift bellow and large bellow look NEW. So, I called my uncle who I bought the boat from and he said yes that a couple years ago he had a guy replace the shift cable and the main LARGE bellow...but he wasn't sure about the bottom one that is cracked up and torn.
to me looks like the large bellow and shift cable bellow are fine no cracks or anything that I can see.
however, like I said the bottom one is cracked up and torn at the front..I should be able to replace this one without taking the drive off correct? I will just need to go through the hole in the outdrive to get the wire clamp screw....simple enough.
I think I'll go that route and next winter redo it all and while the outdrive is off refinish it...I have all factory new MR outdrive decals..took me forever to find them I had to buy a piece at a time off ebay and from doug russell as I found them so can't wait to refinish it next year.
so amI correct on this? going to look for the part on iboats now..surely it shouldn't be more than $50 or so.
