brewern
Thread starter- Joined
- Dec 31, 1969
- 12
Re: Wot @ 3000 rpm?
The problem is the tick doesn't appear when idling. Watch the video and you'll see the tick only starts after the boat is under load. I can rev the engine all day and no tick.
If you have a bad cam lobe, and Chev engines had their share back then, you have a constant partially opening valve meaning that the required air for that cylinder will be reduced. if the lifter is adjusted properly for that bad lobe, there still will be no valve noise. Since an engine is an air machine, and only 4 cylinders, it could seriously affect performance if really worn.
A collapsing hydraulic lifter on the other hand, if leaking, can collapse under pressure. This does 2 things: It won't open the valve fully so you have the same problem as a rounded cam lobe but also, when the rocker turns it (the valve) loose, it (the lifter) may remain in the collapsed state for a half second which is enough time for the rocker to leave the valve then re contact it when it recovers and WALA you have a tick.
I wouldn't expect all your lifters to collapse simultaneously. One or two maybe. So you should be able to go down the valve train with the cover removed and engine idling with something like the tube that paper towels are rolled on and find the ticker(s).
HTH,
Mark
