WOT issues
Deegee
ok i can run 4100 rpm at 3/4 or little more throttle, i hit it down and it wants to go but it wont? it bogs just enough to keep it from going over 4100 but stays at 4100 doesnt drop. any thoughts?
also when im idling around like 1000rpm and i punch it, it hesitates for a second or 2 and then goes?
could i just need a carb rebuild? could a stuck open choke cause this?(just curious)
compression is 135-145 all 4 cylinders
car butterflies are opening right up
3.0 omc 140hp
omc outdrive
17foot thundercraft
liquidlew
Re: WOT issues
Hope your idle speed in nuetral isn't 1000!:eek: Could be tune up~ points/plugs/timing all good?
Deegee
Re: WOT issues
no no lol idle is about 500-600 lol.
i just changed plugs havent dont wires cap points, Probably should try that eh?
