I have a 1989 Force outboard (85hp) with a weird problem.
When we take it to wide open throttle, she doesn't climb out of the
"Hole" for a long time, unless we pump the fuel bulb until she goes, then
everything is fine till we slow her down and attempt to go full bore again.
If we hook up an external electric fuel pump, the motor runs like it is supposed to.
We suspect a bad carb that may be losing fuel pressure around the
bowl and the extra pressure from the fuel pump overcomes the leak.
The question being asked is can the electric fuel pump harm the
engine over time?? Any comments on above thoughts also welcome.
Thanks.
MikeyPa
Thanks.
MikeyPa
