Re: WOT RPM Range
Look at the AV plate @ WOT. If it's buried in water you can come up a hole. Continue raising until the top of the AV plate is just uncovered. This is totally an empirical process and there's no magic relationship that you can just measure, although AV plate even with the hull bottom is a good place to start. At each raise increment, try some hard turns. If you get excessive cavitation, it may be time to back off a hole.
BTW, any decent prop shop will have pitch blocks and can tell you the prop pitch in seconds.
You want to aim for 5800 RPM @ WOT. Hold off on any pitch change until you get the "X" dimension right. You will pick up some RPM and top speed as you raise the motor.
