boat4fishin
- Joined
- Jun 16, 2010
- 20
ok guys getting closer, just a quick recap. hit 4800- 5000 a couple times with a 17 pitch prop, 19 pitch will work perfect when i get one. so anyway. its a 18' 1984 crestline bow rider mercruiser 140. wot RPM stuck at 2200 rpm out of the blue going on two weeks. all filters changes timing is good new point to plugd, no anti syphone valve, no shutter to clogg exhaust area (bellows). 7 about 7 psi of fuel pressure with littl to no air coming from tank. new coil today but there was no lube in the old coil so that might be the problem, coil over heating or did and i think there was a low volage of spark going to plugs, what do you all think.:redface:
