Got 1996 48spl back together and problem with cutting out at wot remains. This only happens at top rpm, and does not do it consistantly. It seems to only happen on initial ride from the trailer to where you go and not usually after that. Problem only happens if the rpm reach about 5600 and not all the time. This is what puzzles me???????<br /><br />replaced so far<br />head gasket<br />spark advance lever<br />thermostat<br />lower unit seals <br />water pump<br /><br />What do you think could cause this wot skip???? <br /><br />thanks<br />longshot
