WOT woes... comp test results
dkellogg3
So, I've been battling WOT problem.... at Chris' suggestion i interrupted fuel sys checks to run a comp test
1994 4.3lx
Results:
1...170
2...175
3...170
4...165
5...175
6...179
Numbers look fine.
Spark plugs...
Port (1,3,5) dark sooty
SB (2,4,6) light sooty
Any conclusions from this?
Back to fuel system...
greg82255
Re: WOT woes... comp test results
1994 4.3lx
Results:
1...170
2...175
3...170
4...165
5...175
6...179
Numbers look fine.
Spark plugs...
Take a look here - go through each test and you should find your problem.
http://forums.iboats.com/showthread.php?t=295070
Failproof
Carbed or fuel injected? Its probably already been said in the other thread but i didnt follow that one.
dkellogg3
Carc. Recently reolaced weber 4 w/ edelbrock. Low wot was the reason for the new carb.
Ayuh,.... Have ya methodically gone down through Don's list of possible causes for this, listed in the Adults Only section,..??
dkellogg3
I am going through the list, and have eliminated all but:
4. Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
I noted the the oil level was a little high yesterday. Maybe 1/8" to 3/16" above the "high" mark. Didn't think that was too high, but...
8. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
11. Fuel pump pressure and vacuum
Did fuel system test yesterday. Hooked the rig up between air/water separator and pump. At idle, air bubble remained right after the separator. Took her out and brought her up to just below where she stumbles (2500rpm) and cruised for a bit. Couldn't get rid of the bubble, and with that in the line, was unable to get any vacuum readings.
Does the fact that all 3 plugs from the port side have dark soot, and all three from the starboard side have light soot mean anything?
THanks,
Don
sharkin95
The compression is very good for a 1994. I would say this is a carburetor issue. try rejetting the #1409 edelbrock, it seems you are getting an over rich issue. My Weber has .089 prim with .089 sec. and 68x57 rods with a 4" hg yellow spring. The #1409 has .098 prim and .101 sec with 68x47 rods and 6" hg orange spring, for my 2 cents this setup is for a v8 not a v6.
Ayuh,.... That would lead me to believe, 1 side of the carb is richer than the other....
With a dual plane manifold, each side of the carb, feeds the opposite side of the motor....
dkellogg3
I was very happy with the compression test. I actually was avoiding it because I was nervous about it, but was relieved with the results. I installed the Edelbrock 1485 kit in the carb during the install. The low WOT was occuring before the carb swap, so I'm thinking although I might need some fine tuning with the Edelbrock, I'm don't think it's the root of my problems. Based on fuel test, I'm finding it odd that I can't pull the bubble out of the supply line.
I'm thinking a new pump is in order.... BUT.... does a restricted exhaust happen often enough that I should look at that first?
Thanks...
sharkin95
it doesn't, but to rule that out I would check the flappers in the exhaust pipe anyway usually you would get a temp increase because of the blockage. a new fuel pump runs about $150.00, did you check the anti syphon and clear the vent?
