Re: Would low tilt/trim fluid cause motor to slowly drop from any level?
Found the problem, there was a leak at the metal hose on the bottom of the reservoir. I thought it was loose, so when i tried to tighten it the whole thing popped out (busted threads on the inside). Am i stuck having to replace the entire reservoir now? I'm not sure where to even purchase one if that's the case. I'm not sure if this is some kind of return hose or if it's actually under pressure 24/7, but is there any type of sealant/adhesive that will hold this back together? I don't think it'd be under alot of pressure since it seemed to strip so easily.
It does look like theres still thread left on the inside in the pics, but trust me, there's not. It will slide right in/out pretty easily...
